43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Draw order furniture/walls
Wed, Mar 29, 2017 at 11:07:15 AM | Draw order furniture/walls
Chiarab
Hello everyone,
Is it possible to chage the draw order in Revit 2017? If I have grey objects close to a wall, the grey lines come in top of the thicker black line of the cutted wall. I found that if I place grey objects first and then walls I don't have this problem, but it's tricky. So my question is if it is possible to bring the grey objects under the wall.
Please see the image attached.
I know that I could use Bluebeam or something similar to set line merge, but I'm looking for a no-expensive solution.
Thanks either way.
Thu, Mar 30, 2017 at 6:23:38 AM | Draw order furniture/walls
Elnazer2
4 Stars: 5 Votes
actually i tried to recreate the problem u have , but i couldn't , both ways the furniture goes under the wall in my project , i changed the category of the furniture to something else and also it wouldn't happen , but if you need an urgent solution - a non expensive one - you can select all your wall and cut them to clipboard and paste at the same place , " if you can attach a file with the wall and the furniture only it would help "
Thu, Mar 30, 2017 at 6:51:29 AM | Draw order furniture/walls
This may not be a real problem, did you check on how it plots?
Your furniture is probably symbollic line work.  Would it really be against the wall?  < Only if wall mounted headboard.
Also make sure you have all your updates installed.  We ask you to include, in your post, what Revit version anmd what update you are using because there are problems that may have been fixed in an update.
Draw order of linked DWGs
Thu, Jun 21, 2007 at 9:14:01 AM
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:32 PM
draw order in revit 2010
Tue, Sep 23, 2014 at 1:24:32 PM
draw order
Wed, Aug 20, 2008 at 8:26:34 AM
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:34 PM
Page generation time: 0.6177
