91 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> View Filters and Linked Models
Mon, Mar 27, 2017 at 3:23:38 PM | View Filters and Linked Models
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I have models linked into specific worksets. For diagramming I'd like to create a filter to highlight models that occur on these worksets. For example, I'd like to have models linked to workset 'x' display lines and surfaces as magenta. I create this filter and Revit ignores it. Suggestions?
Tue, Mar 28, 2017 at 12:45:16 AM | View Filters and Linked Models
Elnazer2
4 Stars: 5 Votes
i had the Same issue , you can't actually filter a linked model only , you can work around it , if you created a dummy workset on the main model with the "exact" same name of the workset in the linked model and then apply a filter to it in the project , it Should work .
Edited on: Tue, Mar 28, 2017 at 2:49:24 AM
Tue, Mar 28, 2017 at 7:53:32 PM | View Filters and Linked Models
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Yeah that's no good. You shouldn't have to chase worksets in linked models to do this task. Thanks for your reply. If I find a work around this limitation I'll repost.
Using Filters on Linked .RVT files
Thu, Nov 30, 2006 at 4:15:18 PM
sheet index order with Linked models
Sun, Mar 13, 2016 at 12:37:28 PM
Linked Models - Element / Component Identification
Tue, Dec 7, 2010 at 4:10:56 PM
Overriding grids of a linked model in view
Wed, Oct 30, 2019 at 10:46:46 AM
Lineweights For System Filters
Mon, Apr 20, 2015 at 2:28:09 PM
Page generation time: 0.8791
