80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Joining a very large amount of instances
Fri, Mar 24, 2017 at 6:41:07 PM | Joining a very large amount of instances
blehrer
Hello,
I have created a generic model family in Revit 2017 and need to array it hundreds of times in my project.  The catch is I need to join these horizontal and vertical instances of the generic model family WITHOUT dividing lines between them, i.e. I need to join them.  It will be too time consuming to do them one by one, even when I select the "multiple objects" from options in Join.  I was hoping I could select all instances of the family and then join, or select join and then do the reverse, to no avail.
Any help would be much appreciated!
Ben
Sat, Mar 25, 2017 at 7:49:42 AM | Joining a very large amount of instances
I doubt that they will join one to one in the first place.  You should have tried that first.
How to mange large amount of instances (links vs. groups)
Fri, Jul 12, 2019 at 6:19:55 AM
Locate instances of family, also Hello!
Tue, May 19, 2015 at 12:34:55 PM
Roof Joining Issue
Mon, Jan 21, 2013 at 7:54:19 PM
12
File size and performance with multiple instances of 3d families
Wed, May 26, 2010 at 4:10:43 PM
Schedule amount of concrete per room
Thu, Nov 25, 2010 at 9:47:53 PM
Page generation time: 0.3481
