76 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Wall surrounding door issues
Fri, Mar 24, 2017 at 1:49:11 PM | Wall surrounding door issues
Bennydablade
Bennydablade Avatar
I have a garage door family I modified from the OTB revit family. Sporatically, it will add the wall from the family into the project. I am attaching an image and the door family. Any suggestions will be appreciated.
DO or DO NOT, There is no try!
Fri, Mar 24, 2017 at 2:41:42 PM | Wall surrounding door issues
Families can not contain walls so if this is part of the family, then the family was built incorrectly.
Fri, Mar 24, 2017 at 2:43:55 PM | Wall surrounding door issues
Bennydablade
Bennydablade Avatar
In the image, there are two garage doors, they are both the same family just different sizes. The 8' wide door shows an additional wall but the 16' door does not...
Fri, Mar 24, 2017 at 2:46:16 PM | Wall surrounding door issues
Please reread my post....
If the family is not the problem then your model is the problem.
In that 3D view, why don't you delete that wall that sticks up through the roof and see what happens.
Fri, Mar 24, 2017 at 2:46:31 PM | Wall surrounding door issues
Bennydablade
Bennydablade Avatar
I Re-loaded the family and it fixed itself!??
Add that to the list of things to try before posting...
Thanks
Fri, Mar 24, 2017 at 2:55:15 PM | Wall surrounding door issues
Bennydablade
Bennydablade Avatar
WWHUB- I did that and it deleted the whole door. Rather than trying to simply place the door again I hit undo once the door and wall disappeared. Messed with the family and checked the parameters and nothing happened. This had happened before and was curious if it was a common glitch. But like I said, I reloaded the family from our library and watched it fix itself once I hit the "overwrite existing".
Thanks again and to all other contributors.
This is my go to site for Q&A!
Door that cuts a curtain and a normal wall at the same time
Sat, Jun 1, 2019 at 7:33:19 PM
need help with my first door family. two issues...
Tue, Jun 5, 2007 at 7:47:52 AM
Storefront Wall - Door Family issues
Wed, Jul 16, 2008 at 1:49:59 PM
Back ground color issues
Fri, Mar 16, 2012 at 1:24:47 PM
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:12 AM
Page generation time: 1.9208
