88 Users Online (86 Members):
Forums >> Revit Building >> Technical Support >> PLASTER WALLBOARD FAMILY
0 Posts No Rating |
Can somebody give me an idea on how can I model this type of wall board including a repetitive support post between the plaster boards ? Furthermore it would be great if doors or windows could be hosted and cut the "wall" wothout having to use voids etc.USING REVIT 2016
Walls in Revit (or any building modeling program) are typically never modeled to this detail level. It is just too much for the systems. Use the standard Revit walls with layers. You won't be able to do studs. In detail views like you show, use detail components.
0 Posts No Rating |
thank u very much
Edited on: Fri, Mar 24, 2017 at 11:42:14 AM
plaster on column? "really in trouble".. |
Tue, Dec 18, 2007 at 9:07:39 AM
(again, sorry) columns with plaster? |
Sat, Dec 9, 2006 at 4:52:30 PM
Single Timber stud to double stud wall doesnt wrap the plaster at the end. |
Wed, Aug 8, 2012 at 5:18:19 PM
Tue, Jul 4, 2006 at 6:29:22 AM
Creating a steel column with insulation and plaster cover |
Thu, Nov 24, 2016 at 11:39:44 AM
Members: | 2030550 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
