39 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Tips & Tricks >> Steel Structure Object Style
Thu, Mar 23, 2017 at 4:43:25 AM | Steel Structure Object Style
Menia
Hello,
I have a problem with the visibility settings in revit 2016. I have to built a steel structure with 20 different welded beams.
These beams are subcategorized in "structural framing". So, in the plan view all the beams are of the same color. No matter if i change the material (dublicate steel material with different color and align them to the different sections), no change in plan view!!!
I also created a subcategory object style under "structural framing" but i cant align it to to the beams.
The main problem is that i need to export this file to an autocad file, so the different color or layer in every steel section of major importance!
Thank you in advance.
Fri, Nov 24, 2017 at 12:54:10 AM | Steel Structure Object Style
Jezzza
There are a few ways you can achieve this, but they are all hacks/workarounds
#1. Create a Symbolic line in the family with different colours. You can use on/off instance parameters or you will need to create 20 seperate families though, one for each beam type
#2. Use filters and a parameter value. You could add a shared parameter, or use one of the family parameters (could use beam size if they are all different)
#3. (Assuming you are showing the beams as single lines) You can use the linework tool to override graphics
Fri, Feb 22, 2019 at 5:51:22 AM | Steel Structure Object Style
vedika31
Hey Jessa,
Yours points were relevant and informative.
Steel Structure
Fri, Mar 11, 2005 at 1:39:35 PM
Detail Component Object Style?
Fri, Apr 9, 2010 at 10:01:48 AM
revit steel questions
Mon, Apr 6, 2015 at 9:27:20 AM
True plan view of sloped steel?
Mon, Feb 27, 2017 at 9:31:22 AM
14
OBJECT STYLE ISSUE
Fri, Jan 30, 2015 at 10:34:36 AM
Page generation time: 1.6864
