Forums >> Revit Systems >> Technical Support >> Elevations - Hide at Scales Courser Than
Mon, Mar 20, 2017 at 10:16:42 AM | Elevations - Hide at Scales Courser Than
cboersen
2017 OS10
Sections "Hide at Scales Courser Than" will delult to match the scale of the plan that the section is cut in, but elevations always defults to 1:400.  Is there a way to change that defult?
Mon, Mar 20, 2017 at 12:19:59 PM | Elevations - Hide at Scales Courser Than
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
You can create a view template and apply it to all new views that will be created in the future. Works the same way for plans, elevations, structural plans, etc.
Mon, Mar 20, 2017 at 1:59:16 PM | Elevations - Hide at Scales Courser Than
cboersen
View Templates do not have a setting for "Hide at Sclaes courser Than" (at least none I can think of) so what are you proposing to do in the View Template?
Mon, Mar 20, 2017 at 2:14:01 PM | cboersen
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting cboersen from 2017-03-20 10:16:42
...to set a desired scale, other than 1:400. Isn't that what're asking for?
Mon, Mar 20, 2017 at 3:11:41 PM | Elevations - Hide at Scales Courser Than
cboersen
True, you can set a scale in a view template, but that is not what I am looking to do.  I want to control the "Hide at Scales Courser Than" parameter for an elevation mark not set the scale for an elevation view. My fault for not being clear.
Default value "Hide at scales..."
Mon, Mar 3, 2014 at 9:17:22 AM
Door/Room Tags in Callout Detail
Thu, May 17, 2007 at 2:58:20 PM
Section cut tag not showing on foundation or roof framing plan..
Sat, Nov 1, 2008 at 7:54:03 AM
Building Section callout not showing in plan views
Fri, Mar 11, 2016 at 3:18:03 PM
not changing
Wed, Jul 8, 2009 at 1:26:58 AM
Page generation time: 0.5321
