34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing wall types midmay through wall
Mon, May 22, 2006 at 1:25:20 PM | Changing wall types midmay through wall
ddjwh1
I am trying to "break" up the patterning on an exterior wall. I have created a different wall type with a different exterior finish pattern and split the existing wall and changed the type. When I view the wall in 3D the pattern has not changed. The wall type has changed. ddjwh1
Mon, May 22, 2006 at 1:45:34 PM | RE: Changing wall types midmay through wall
quiller
quiller Avatar
2.5 Stars: 3 Votes
Did you dulicate the existing wall and then change the material of the wall? If not delete the wall you created and duplicate the wall you started with, change the name and then go into the properties/structure of the wall and change the material of the wall. It should show up.......I just did a little test and I could not find a way to not have it show up.
Changing line types and styles in cross section views, wall types etc...
Wed, Apr 12, 2006 at 12:52:33 AM
Wall Dimensioning changing after changing Wall Type.
Wed, Aug 31, 2016 at 7:58:32 AM
Copying Arch Wall Types
Tue, Aug 14, 2012 at 9:18:27 AM
Changing different glass types in one curtain wall
Tue, Feb 27, 2018 at 8:36:54 AM
How do I make custom wall types publicly accessible?
Sun, Apr 4, 2010 at 2:17:09 PM
Page generation time: 3.3560
