143 Users Online (141 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Property Arcs - Input Delta Bearing
Mon, Mar 13, 2017 at 1:47:45 PM | Property Arcs - Input Delta Bearing
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
How do you input an arced property line in the table when there is a delta value for the bearing versus N/S, E/W? I tried subtracting from the previous bearing, 90 degrees, but I'm not correct. Does Revit have a way to understand this explicitly? Thanks.
Mon, Mar 13, 2017 at 2:54:38 PM | Property Arcs - Input Delta Bearing
You still need a bearing.  If you don't have the direction, guess and see what it looks like then revise if needed.
Mon, Mar 13, 2017 at 3:02:10 PM | Property Arcs - Input Delta Bearing
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I'm finding that I have to perform my own calculations to get the right bearing. I was hoping Revit would have had a way to do this more automatically. Thanks for confirming. I guess Autodesk will have to update the functionality of this feature to allow input for survey information given in this format. Cheers.
Mon, Mar 13, 2017 at 3:15:11 PM | Property Arcs - Input Delta Bearing
How could it be automatic, not all arcs are tangential?  Every good survey I have ever seen has the bearing angle.
Mon, Mar 13, 2017 at 3:28:26 PM | Property Arcs - Input Delta Bearing
BTW - Just looked at your image.  Flip the L/R in your table.
ROUNDING VALUE ON PROPERTY LINE BEARING
Fri, Apr 8, 2016 at 1:13:37 PM
Property Lines + True North Rotation
Thu, Apr 26, 2012 at 2:34:45 PM
Property line tables on sheet
Tue, Mar 14, 2017 at 1:29:57 PM
Revision Schedule with Delta symbol?
Mon, Dec 20, 2010 at 2:54:29 PM
Property Lines
Tue, Apr 16, 2013 at 3:48:47 PM
Page generation time: 0.3650
