Forums >> Revit Building >> Technical Support >> Door handle not on a door plane
0 Posts No Rating |
I have downloaded a door with frames which I deleted and I think after that the door handle started floating in the air (see images attached). I tried fixing it, but when I go into family edit mode, the handle seems fine. Anybody has an idea how do I fix it?
Thanks in advance
It looks like the handle is constrained to the face of the wall, not the face of the door panel. Change the wall thickness in the door family to see what I’m talking about. If still no go, upload the family so we can troubleshoot.
0 Posts No Rating |
Seems like still no go, maybe a former door frame had something to do with it. It's long gone anyway.
Edited on: Mon, Mar 13, 2017 at 8:20:22 AM
Yeah, something else is going on with those handles and locks. Just delete them and reinsert, fix their constraints, so they are attached to the door panel and it should work.
As a reminder: geometry should not be constrained to other geometry. Always create ref plane skeleton first, apply dims and parameters, flex them and at the end apply geometry and constrain it to the ref planes and flex everything again.
0 Posts No Rating |
Will work on that thanks for replying so soon
0 Posts No Rating |
I'd probably give up on that one
0 Posts No Rating |
I have a quetsion.
I have inserted all my doors on my drawing but the handles don't seem to be showing up.
Any pointers??
try the visibility settings , maybe its only contrained to show on fine views only
0 Posts No Rating |
That worked! Thank you
Door handle |
Thu, May 19, 2011 at 6:19:46 AM
FAMILY DOORS WITH PARAMETRIC DOOR HANDLE |
Wed, Jan 4, 2006 at 11:09:34 AM
Why isnt the Range Top, knobs and door handle not showing up in my Rendering |
Thu, Dec 4, 2014 at 12:30:51 PM
Door Handles |
Mon, Apr 1, 2013 at 9:30:51 AM
Door Hardware |
Thu, Nov 23, 2017 at 11:05:25 AM
Members: | 2101440 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
