109 Users Online (106 Members):
Forums >> General Discussion >> Revit Project Management >> Face Based Families & Basic Ceilings
![HelmetFire Avatar](user_avatar/1035855.jpg)
Ladies & Gentlemen,
The Goal
To have a set of face based families for use in reflected ceiling plans so that in the event a user accidentally deletes a ceiling they won’t also delete the elements hosted by it.
The Snags
When placing these families in a basic ceiling (as may happen during design) they won’t cut the ceiling.
When changing a compound ceiling that is being cut by these families to a basic ceiling (which is a possibility I can’t rule out) I am forced to delete the family instances because Revit “Can’t cut instance(s) of it out of it’s host” and “Highlighted geometry no longer determines a plane.”
Are these snags related to the limitations of basic ceilings or am I overlooking something? Thanks.
Sorry - I don't have an answer for your problem. It looks like your real problem is your users. I think that is an issue that should be addressed rather than accomodated. Users should always check their selection set when deleting items. It's often a surprise to find out what is in there. BTW, you can always copy/paste a ceiling and hosted items from a previous file into the one where they were lost.
I thought the old 'basic' ceiling was gone in the latest Revit but I may be mistaken. The basic ceiling that I remember is really not a physical ceiling. It had no physical properties and that's why there would be nothing to cut. In early releases, we had always used this to apply a 'ceiling' to an exposed structure and have something to host ceiling hosted elements.
I understand that a lot of MEP guys are pushing for face based because some architects carelessly delete ceilings.
Scheduling Problem with Face Base Families |
Tue, Jul 15, 2014 at 8:59:16 AM
Face-Based Sinks on Countertops |
Fri, May 13, 2016 at 12:14:08 PM
Plan annotations for face based families |
Tue, Feb 8, 2011 at 8:59:45 AM
Converting Ceiling Based families to Face Based Families |
Tue, Jun 12, 2018 at 7:13:41 PM
Faced-based families Revit Systems |
Wed, Oct 3, 2007 at 6:23:30 PM
Members: | 2017318 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
