50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Floors and walls being transparent in 3D view
Tue, Mar 7, 2017 at 1:44:42 PM | Floors and walls being transparent in 3D view
Rebelous
Hi I'm having a problem with my foundation walls and pad being transparent as well as my 2nd floor. Any help please?
Tue, Mar 7, 2017 at 2:02:11 PM | Floors and walls being transparent in 3D view
Many possible reasons but you have not given us any history.
  • Element over-rides in view
  • material settings
Tue, Mar 7, 2017 at 2:09:41 PM | Floors and walls being transparent in 3D view
Rebelous
Well it just happened when I started up my project. I stared on a contruction template while on revit 2016. Then my foundation waws transparent in relistic view but in any other view its normal for revit
Wed, Mar 8, 2017 at 2:26:44 PM | Floors and walls being transparent in 3D view
Change the view discipline and see what happens.
Thu, Mar 9, 2017 at 12:53:28 PM | Floors and walls being transparent in 3D view
Rebelous
I tried the displine nothing happend any other ideas?
Thu, Mar 9, 2017 at 1:31:58 PM | Floors and walls being transparent in 3D view
Check out what I listed before and look for a template.
Are you sure the walls are even on?
Thu, Mar 9, 2017 at 1:37:22 PM | Floors and walls being transparent in 3D view
Rebelous
Yes i am because i can see the first floor just fine its just the foundation and the second floor that are transparent. T he thing i find odd is it onlt happens on realistic not consistant colors
Thu, Mar 9, 2017 at 1:42:27 PM | Floors and walls being transparent in 3D view
Rebelous
This is what it looks like
Thu, Mar 9, 2017 at 2:37:27 PM | Floors and walls being transparent in 3D view
You have some sort of filter applied or the wrong materials assigned, it is a user setting somewhere.  It could be a phase filter it could be an over-ride.
We can only help if you give us enough information.  Did you create this project?
Show us the properties for the transparent walls.   Then show us the material settings for those walls.
Fri, Mar 10, 2017 at 7:28:57 AM | Floors and walls being transparent in 3D view
kkozak2
I had a similar problem on one of my projects. In my case, it was the phase filter that was set to "Show All". I changed it to "Show Complete" or "Previous plus New" and it fixed it. Just a thought.
Fri, Mar 10, 2017 at 2:20:46 PM | Floors and walls being transparent in 3D view
#11
Rebelous
kkozak2 that worked and WWHub thank you for helping me out as well.
Thu, Nov 12, 2020 at 2:52:52 PM | Floors and walls being transparent in 3D view
#12
rmessiana
I was having the same problem with walls showing up as transparent when the view filter was set to "show complete". when i looked at the finish material on the wall, i discovered that in the material browser, the material graphics had a transparency set under the graphics tab. once this was set to 0, the problem went away.
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Floors appears to be floating in transparent green
Fri, Jan 29, 2016 at 7:50:07 AM
Non Transparent Curtain walls in 3D View?????????
Fri, Sep 11, 2009 at 1:48:58 AM
Revit 9.1 ability to make transparent floors?
Thu, Nov 29, 2007 at 4:54:15 PM
VG Filtering Walls by Different Base Contraints
Wed, Apr 1, 2015 at 10:22:28 AM
Page generation time: 1.1627
