53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> light wiring in architectural floor plan
Sat, Mar 4, 2017 at 10:47:03 AM | light wiring in architectural floor plan
brankulo
is it possible to make light circuiting show in architectural light plan? i have found out how to show lights and switches, but cant figure what to do with wiring
Sun, Mar 5, 2017 at 10:17:46 AM | light wiring in architectural floor plan
What do you really want?   If you want what we used to draft, then do that.  Annotative (2D) lines.
Sun, Mar 5, 2017 at 1:43:57 PM | light wiring in architectural floor plan
brankulo
like is wrote. i need to show wiring done in electrical to show in my architecturals. i can redraw but if i can just turn the existing ones from electrical it would be much quicker
Sun, Mar 5, 2017 at 3:14:30 PM | light wiring in architectural floor plan
You said nothing about having a linked in electrial plan.  If their's is in Revit and it is 3D, you can turn it on.   If it is 2D, you can link their view.
Why would you want to show electrical in the architectural if it is already done?  Just a problem ahead.....
Sun, Mar 5, 2017 at 5:17:04 PM | light wiring in architectural floor plan
brankulo
It is not linked. It is drawn within the file. I have inherited this project and need to finish. Some of the municipalities here require outlet/lighting plan that shows switching, as part of architectural set.
Mon, Mar 6, 2017 at 9:26:59 AM | light wiring in architectural floor plan
You say it is drawn in the file.  If 2D, simply copy / paste into your plan.
Floor plan showing ceiling fixtures and wiring to switches
Wed, Feb 18, 2009 at 2:49:45 AM
Light switches not showing on floor plan
Fri, Apr 29, 2011 at 2:14:20 PM
Electrical wiring
Wed, Nov 12, 2008 at 4:22:37 AM
Lighting plan visibility issues
Thu, Sep 27, 2007 at 11:41:58 PM
Labeling wiring runs with panel name
Mon, Jul 14, 2008 at 9:47:53 AM
Page generation time: 1.4102
