Forums >> Revit Building >> Technical Support >> Revit 2017 shuts when either opening, saving or closing a window.
Hi, I am in need of some help, the problem i am having is that on most of my revit drawings when i either save a job or close the window revit pops up with a message and closes, the message says;
Autodest Revit has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
I dont believe that the RVT files are broken, or over complicated that it would make revit shut down everytime.
Do any of you guys have a solution?
Many Thanks
Calman
Some people may be able to help if you provide information we should not have to ask for.
- Revit issue and updates
- Your equipment / operating system - available disk storage
- Your file size
- Are you closing from tiled windows?
- Revit issue and updates Not sure but i am up to date according to the autodesk manager.
- Your equipment / operating system - available disk storage Windows 10 we are working from a network with 561gb free storage
- Your file size Its all files so cant give you all the sizes but range from 1mb - 23mb.
- Are you closing from tiled windows? Yes
I hope this helps a little, im not very computer technical, I have a feeling it is a Windows 10 thing as this never happened on Windows 7.
First - get up to date.
You say you are working on a network.
- Are you using work sharing?
- Is this a local file being saved on a network? (Should not save lovcals on network)
- If worksharing, you have to give Revit time to update the central before closing your local.
- Closing files from tiled windows results in a very big file size. It is always best to close all windows but one before saving. We actually closed from a very small view that described the project.
Revit shuts down without warning? |
Tue, Jun 3, 2008 at 3:55:38 AM
Bi-Fold doors parametrics for opening and closing 3d panels by percentage? |
Wed, May 16, 2012 at 10:14:46 PM
Open Family Editor in Floor Plan View by Default |
Thu, Jan 12, 2017 at 6:20:21 PM
Window Head / Opening Cut |
Mon, Feb 10, 2014 at 7:31:00 AM
window opening |
Mon, Aug 24, 2009 at 8:03:19 AM
Members: | 2098160 | Objects: | 23164 | Forum Posts: | 152291 | Job Listings: | 3 |
