67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Structural Connection not visible in Detail
Howdy everyone,
Anyone shed some light on why the structural connection is not visible in the detail?
VG is all turned on and the phasing is the same, Connection is visible in Perpective but not detail
Please see attached
Cheers
Shawn
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
try to switch between detail levels , this is the problem probably , or it is the visibility settings inside the family geometry itself look at that link
First thing that comes to mind is View Range.
Which 'level' is the floor plan call out detail taken from - and does the view range extend down to the level below if you have taken the callout from the level at top of the C channel ring beam ?
Tried both things, you cant change the visibilty settings in the family as it is a system family and there is no editable elemants,
I ended up deleting it and redoing the connection, somehow this has worked?
Teething problems with revit struture 2017 possibly?
Cheers
Shawn
Structural framing not visible in plan |
Tue, May 20, 2008 at 4:56:35 AM
Revit 2017 Structural Connection - where is material defined? |
Wed, Jan 25, 2017 at 3:23:28 PM
structural truss element not visible in section |
Sun, Jun 28, 2020 at 7:05:03 AM
Piping Medium Detail Issue at Mechanical Equipment Connection |
Thu, Sep 27, 2012 at 3:45:11 PM
building sections visible but detail view sections NOT visible on all drawings?? |
Tue, May 27, 2008 at 12:50:20 PM
Members: | 2022290 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
