90 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> BIM 360 & REVIT IPD
Fri, Feb 17, 2017 at 10:08:57 AM | BIM 360 & REVIT IPD
PaulM3357
Dear Collegue:
I’m in the process of testing and setting up a MEDIUM  size IPD REVIT project and would like to know what ae the pros and cons of IPD verses link model process. What are the main benefit for doing REVIT in IPD (with all discipline working in the same model).
I can see some of the benefit on coordination issue, but there is also a great fear from consultants worrying that their work can be accidently modify by other team members. If there are errors and omission as a result of this type of incident, claiming insurance will be an issue.
We can always use Worksets to lock down our own work in the project file.  In my experience, working with a project file with everything locked down is not always effective.  There will be a lot of editing request and waiting around for request to be granted.
Also I’m trying to work with BIM 360 for collaboration with REVIT and have a few question regarding the process (see video link attached).
https://youtu.be/zt9Da7TxriI
While work with Manage A360 Model from inside REVIT, I find it difficult to delete project file and it will not allow me to upload and replace REVIT project file in the BIM360 folder.  Any workaround or insight will be greatly appreciated.
Thanks in advance for yor comments!
Best Regards,
PaulM
Fri, Feb 17, 2017 at 1:29:09 PM | BIM 360 & REVIT IPD
IPD and link model are not competative, you can do both with the same model(s).
All disciplines working in the same model is not good practice and no reason to do it.  We always use seperate models for each discipline be it a normal project or IPD.
Can't Remove File from BIM 360
Wed, Apr 10, 2019 at 8:59:17 AM
BIM 360 Link Issues
Wed, Sep 12, 2018 at 12:10:51 PM
Sharing Revit Models and content - BIM 360, etc
Fri, Jan 11, 2019 at 4:17:09 PM
What happened to C4R Communicator?
Fri, Aug 16, 2019 at 10:12:10 AM
Technical Document Management & BIM collaboration tools
Fri, Aug 6, 2010 at 5:27:34 AM
Page generation time: 3.1061
