133 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rotation along two axis
Tue, Feb 14, 2017 at 8:42:06 AM | Rotation along two axis
unnbe
Hi everyone!
Any idea on how to incline the leg of the table as shown by the picture? The leg is a sweep of the same family, created on a vertical plane of course.
Tue, Feb 14, 2017 at 8:46:25 AM | Rotation along two axis
unnbe
With this second picture I simulated my desired result (if not already clear). Winking
Tue, Feb 14, 2017 at 9:03:13 AM | Rotation along two axis
Best practice since you have 4 legs is a nested family.
Tue, Feb 14, 2017 at 5:31:25 PM | Rotation along two axis
unnbe
Is it possible to create a reference plane passing through 2 reference lines?
Even using nested families my problem would be the same. I have to rotate the leg, first, 45° on the Z axis and then 20° on the axis passing through the top of the leg...
:S
Tue, Feb 14, 2017 at 5:59:05 PM | Rotation along two axis
archigrafix
5 Stars: 4 Votes
Rotating in plan is easy, you use any plan drawing. The key to the inclination is to place a reference plane in the direction of the inclination, passing by center of the leg. Then you name that reference plane, and select it from "Set plane". You should orient a view to this reference plane. At this point you can do you rotation of your object to incline it as you require.
You will need a longer leg. You can make all sort of planes, or use help solids to make views coincident/aligned to faces to work in non orthogonal planes.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
objects move in Y-axis but not X-axis
Wed, Nov 2, 2005 at 11:04:31 PM
Axis in elevation is funky
Wed, Mar 25, 2009 at 1:07:48 PM
Leaning columns
Thu, Jun 25, 2009 at 2:07:41 PM
rotating in Y axis?
Wed, Feb 13, 2013 at 3:30:01 PM
Revolve along a curved axis?
Tue, Apr 1, 2008 at 3:40:01 PM
Page generation time: 0.2709
