171 Users Online (170 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Variable Thickness Wall?
Thu, Feb 9, 2017 at 7:24:07 PM | Variable Thickness Wall?
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I came across this in my project today and I was stumped: A wall that had a variable thickness for it's core structure but still reported 11-5/8" thickness. It's not modeled as an in-place family. It's an honest to goodness wall. Huh? How is this possible? How do you create something like this?
Fri, Feb 10, 2017 at 9:29:33 AM | Variable Thickness Wall?
It is variable because each of those horizontal split regions can be set to different thickness.
Read this help: http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-91584C23-7FB5-46DD-82D1-48F36F3B4804
Fri, Feb 10, 2017 at 12:32:18 PM | Variable Thickness Wall?
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Ah ha. I see. In all these years I've never used this tool. I've definitely modified the vertical section to allow for variable heights of layers, but never had a use for split region. Thanks for the help link to define which tool was in use. That helped find other links to see what it's used for. Have you ever used split region for defining coarsing like I discovered? Seems redundant if you use the appropriate model pattern unless it helps constrain coarsing dimensions vertically? That also sounds redundant. Trying to unpack the logic of why someone might create a cmu wall that way.
Fri, Feb 10, 2017 at 12:41:37 PM | Variable Thickness Wall?
I have used the split region and even assigned a different material like brick in a block wall.  Also works for recessed or stepped out coursing.
Fri, Feb 10, 2017 at 6:09:59 PM | Variable Thickness Wall?
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Gotcha. Well I definitely learned something new about Revit today. Thank you sir!
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:45 AM
Roof with variable thickness on sloping framing
Wed, Jan 20, 2010 at 10:12:07 AM
Wall layer thickness turned "variable"
Wed, Aug 21, 2013 at 3:25:35 PM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:16 AM
Sloped solid roof with variable thickness
Tue, Feb 21, 2017 at 4:09:25 PM
Page generation time: 0.9247
