39 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> Elevation Levels are not matching with Project browser.
Hello guys,
The attached image is from our designer drawing.
I could see all the levels in elevation. And all of them had been used in the drawing.
But in the project browser it shows different.
As per my knowlede If we change name of the level in elevation It would automatically update in the project browser isn't it?
Please help me to find out how it could have been done.
I would like to follow the same style as it looks well organized.
Please see the attached pictures.
Thanks.
i think to answer your querry there is 2 point on that :
1) The black label levels doesnt have plan views created with them and here is a link explaining the difference briefly .
2)is that you need to be familiar with the browser organization and how it works and learn how to sort it and filter it if needed ( in this case i think your plans that you need are inside the "??" down your browser , here is a link from the autodesk help
In addition, you can rename a level or plans independent of each other. If the plan was created with the level, Revit will give you th option to rename the other (plan/level) when you rename a level/plan.
Thanks Elnazer2 & WWHub,
Your answers helped me really.
The link explained well.
where is my elevation on project browser?? ( beginner) |
Mon, May 2, 2011 at 12:28:35 PM
Plan in Project Browser |
Fri, Oct 10, 2014 at 9:15:22 AM
Floors are not showing up in the project browser |
Sat, Apr 21, 2012 at 6:18:20 AM
2nd floor isn't visible in project browser |
Fri, Feb 28, 2014 at 9:55:02 PM
getting the levels and elevation from linked file |
Sat, May 14, 2016 at 5:25:06 PM
Members: | 2022332 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
