47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Model in place cut plan for extrusion
Thu, Feb 2, 2017 at 9:06:41 AM | Model in place cut plan for extrusion
SteveB
3.5 Stars: 5 Votes
can you move the cut plane for the sketch... see pix attached
Thu, Feb 2, 2017 at 10:12:08 AM | Model in place cut plan for extrusion
3.5 Stars: 395 Votes
The cutplane is always in the middle of your first sketch line.  Sometimes, I have even used multiple line segments on one edge when I wanted this in a very unique location.
Thu, Feb 2, 2017 at 11:34:57 AM | Model in place cut plan for extrusion
SteveB
3.5 Stars: 5 Votes
Yes, I've noticed that, thanks for the response WWHub.    Just have to be careful to draw the path starting where you've already got the sections and leave it at that.
Thu, Feb 2, 2017 at 11:36:18 AM | Model in place cut plan for extrusion
SteveB
3.5 Stars: 5 Votes
Your tip about multiple line segments is helpful to get the section to fall in the part of the line that is appropriate.
Thu, Feb 2, 2017 at 11:59:21 AM | Model in place cut plan for extrusion
BTW - If you delete the first sketch line, the second one is now first and the cutplane moves.   Then you can add the deleted line back in.
Thu, Feb 2, 2017 at 1:54:44 PM | Model in place cut plan for extrusion
SteveB
3.5 Stars: 5 Votes
Good tip as well.
Can I cut a hole through an extrusion?
Fri, Apr 13, 2007 at 8:31:51 AM
Any way to cut an in-place roof?
Mon, Nov 25, 2013 at 1:57:06 AM
Model-In-Place Component adhering to plan's view range.
Mon, Apr 12, 2010 at 12:18:43 PM
re-joining (?) cut extrusion with extrusion
Tue, Apr 17, 2007 at 10:26:27 PM
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:26 AM
Page generation time: 1.9602
