88 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> double acting door family swing angle parameter
I created a double acting door family with a swing angle parameter that allows the user to change the angle of the symbolic lines that represent the door swing in plan view. with the double acting aspect I have symbolic lines that represent the door swing in plan on each side of the wall. for some reason I cannot change the swing angle greater than 88 degrees. when I choose to go greater the family breaks and I get several error messages. I am attaching the family for your review. the family was originally built in revit 2015
Read the Variable Angle Door Swing breaks at 150° post listed in similar threads below.
May I suggest you pull your dimensions from Ref. Planes - not the symboloic linework itself - and have your symbolic line work aligned, locked and dimensioned from those/to those Ref Planes.
Edited on: Fri, Feb 3, 2017 at 10:23:42 PM
creat double door w/ adjustable swing |
Mon, Apr 27, 2015 at 1:30:05 PM
Nested Door Family w/ Adjustable 3D Swing Angle |
Tue, Jul 31, 2007 at 5:34:20 PM
3D Swing parameter!! Help!! |
Sat, May 11, 2013 at 7:03:34 AM
Variable Angle Door Swing breaks at 150° |
Fri, Sep 12, 2014 at 4:39:10 AM
Fully Parametric door with 45 angle swing |
Thu, Apr 4, 2024 at 8:17:09 PM
Members: | 2057641 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
