105 Users Online (103 Members):
Forums >> Revit Systems >> Technical Support >> Wall Sweeps - Changing the modified return to slope downwards, not up
0 Posts No Rating |
I've modeled the concrete curbs several ways in my project - it's a large food processing plant with curbs in every production room.
My problem is when these curbs are modeled as part of the wall assembly AND as an external sweep, the "modify return" works only part of the time. *(Recognizing that part of the problem lies in how close doors are hosted to the edges adjacent to overhead doors) - Any other suggestions for this part?
With that said- here's the big problem- I need to model the return as sloping DOWN and not up as apparently is default. Anyone know how to change that?
THANK YOU in advance,
I cannot recreate your issue here. Can you upload rvt file with your wall, sweep and the door that causing the problem, so we can troubleshoot?
Wall Sweeps - Changing the modified return to slope downwards, not up |
Wed, Mar 28, 2018 at 11:45:30 AM
stair tread return |
Tue, Sep 2, 2014 at 6:13:48 PM
sweeps and wall styles on sloped walls |
Mon, Apr 14, 2008 at 1:28:22 AM
Wall Sweeps |
Sat, Dec 1, 2007 at 2:08:59 PM
Wall sweeps to deep reveals |
Tue, Jan 11, 2005 at 4:07:26 AM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
