41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Curtan wall panels transparency.
Wed, Jan 25, 2017 at 2:23:29 AM | Curtan wall panels transparency.
lukdab
Hi.
I want some of my panels nontransparent. Their surface is the same glass as in transparent ones but deeper there are few more layers.
I made a wall with layers I wanted, changed the panels type to that wall and change category to "panel".
Everything works fine except the panels are transparent and I don't know how to change it. It looks like all panels are set to be transparent despite materials they're made of.
Wed, Jan 25, 2017 at 7:41:07 AM | Curtan wall panels transparency.
marmiketin1
4.5 Stars: 10 Votes
select panel -> edit type -> edit material -> duplicate material (optional but recommended) -> appearance tab -> transparency -> check the box to activate transparency if not already and then edit the properties
Thu, Jan 26, 2017 at 2:18:24 AM | Curtan wall panels transparency.
lukdab
Nope.
It's a wall inserted in place of curtain panel. It has no transparency.
Thu, Jan 26, 2017 at 7:59:55 AM | Curtan wall panels transparency.
3.5 Stars: 395 Votes
I'm lost.  You can always substitute a wall for a curtain panel but it still works like a wall.
Thu, Jan 26, 2017 at 8:31:37 AM | Curtan wall panels transparency.
lukdab
And when you select that panel(wall) you can change its category (wall or panel).
But it displays with transparency... in my case the wall has few layers, none of them is transparent.
Basic Wall as Curtain Wall panel transparency incorrect.
Wed, Nov 23, 2011 at 9:37:16 PM
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:57 AM
Turning certain curtain panels into spandrel panels
Tue, Dec 3, 2013 at 1:59:47 PM
Hatching for Pre Cast panels
Wed, Apr 17, 2013 at 2:38:49 AM
Interior Walls - Wainscot Panels - Revit 2018.2
Mon, Feb 12, 2018 at 4:55:14 PM
Page generation time: 0.7129
