Forums >> General Discussion >> Wishlist >> selection filter
Sun, May 21, 2006 at 2:42:36 AM | selection filter
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
I would like to use the selection filetr in Revit with the capability to filter, for each category, every object in the scene.Almost like in 3d studio max. So if you have a scene with 5 walls, 3 windows, 2 floors ect...when you filter the selection you would be able to select or unselect wall #1,wall #2 ect...sorting the objects within their properties. I think that it will enhance Revit capabilities.
Sun, May 21, 2006 at 5:26:22 PM | RE: selection filter
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is sort of possible using Shift+Click...
Sun, May 21, 2006 at 6:54:21 PM | RE: selection filter
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
I'm sorry but I think that there was a misunderstanding: I want to be able to select or unselect an object such as a specific kind of wall, or window, or anything else, directly from the list that appears after you press the selection filter button, but not directly in the scene, because you can be in the case that you have too many objects of the same type to choose easily from one another...also you should be able to hide an unhide by name every object in the scene and not for type like now happends. These are features present in 3ds max, and so I think Revit users will appreciate this further filter capability. by the way,thanks for the answer. paolo Post edited on 2006-05-21 18:55:33
Sun, May 21, 2006 at 9:32:56 PM | RE: selection filter
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yeah agreed would be nice to quickly select all of one particular wall category in a view without the need to resort using filters...
FILTER HOTKEY
Tue, Sep 17, 2013 at 1:34:53 PM
Rule-Based Filter SELECTION
Sun, Dec 9, 2018 at 6:56:29 AM
Selection Box Doesn't Include Ceilings
Tue, Jan 8, 2013 at 3:51:20 PM
selection issue
Fri, Mar 4, 2005 at 3:43:11 PM
Stumped on why window selection or crossing selection wont pick pipe fittings ?
Sat, Jun 1, 2024 at 1:44:16 PM
Page generation time: 1.6639
