132 Users Online (130 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Balcony construction detail
Tue, Jan 24, 2017 at 4:34:26 PM | Balcony construction detail
vnd
3 Stars: 2 Votes
This is an unusual request, as its not revit related, but would anyone have a construction detail for a balustrade post connection/fixing to a tiled, water proofed balcony over a living space?
Ive attached the pdf file of it here if anyone is curious enough to have a look and share what they might have.
Thanks
VND
Mon, Jan 30, 2017 at 11:02:31 PM | Balcony construction detail
DavidBruinsma
Hi vnd
I would recomend a Google search on Wet Decks, one of the obvious choices would be James Hardie
http://www.jameshardie.com.au/technical/application/decking/
Another result is:
http://wet-seal.com.au/waterproofing-balconies-balcony-deck-waterproofing/
Or you can read through this site, for a wet seal application to go under a 'tiled' floor finish
http://www.flexaseal.net.au/service_view/terrace-deck-balcony/
I also found the VBA information data sheet, if you are interested, not specifically for wet decks though:
http://www.vba.vic.gov.au/__data/assets/pdf_file/0007/20959/Balconies,decks-and-balustrades.pdf
I hope something in the above you will find helpful.
Tue, Jan 31, 2017 at 8:03:15 AM | Balcony construction detail
marmiketin1
4.5 Stars: 10 Votes
Here is a pretty thorough write up on how to properly insulate and ensure continuity of water membrane/barrier.
https://buildingscience.com/documents/insights/bsi-051-decks-roofs-you-can-walk-on
As for securing the railing you would want to mount the post base plates on top of some sort of gasket that compresses to ensure no water will penetrate at the fastener locations and then tile around the base plate of the posts
Level 2 (Upstairs) and Balcony floor
Thu, Feb 11, 2016 at 4:03:27 PM
Balcony
Sat, Mar 31, 2007 at 3:43:32 AM
Corbel Sweep through the balcony
Thu, Feb 25, 2016 at 8:10:36 AM
Curved roof terrace/balcony....
Thu, Nov 18, 2010 at 8:45:45 AM
Existing wall assembly visable in New Construction phase
Wed, Nov 2, 2011 at 5:49:10 PM
Page generation time: 1.5979
