70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Btween program convert files
Sun, May 21, 2006 at 1:37:04 AM | Btween program convert files
knight
-How to make the convert from AutoCAD 2D/elevation to Revit 3D look and walkthrough? -When I import the autoCAD file to Revit which I can see the file over floor plan but cant see it over elevation. Does Any solution? -Btween Revit, autodesk VIZ, and 3Ds Max which is the pros and cons for 3D look and wlkthrough? Post edited on 2006-05-21 01:38:31
Sun, May 21, 2006 at 5:29:41 PM | RE: Btween program convert files
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately Revit is not Psychic yet... Smile Revit does not automatically convert a 2D AutoCAD plan into revit 3D elements, which is why you see nothing in elevation. You need to sketch over the top of the autoCAD file with Revit objects in order to get any 3D geometry. If your autoCAD is a 3D file, make sure when importing you don't have current view only ticked as if it is it will only be imported as 2D information. HTH.
How 2 convert more number of Revit (*.rvt) to AutoCAD(*.dwg) files @ a time
Fri, Aug 28, 2009 at 6:40:58 AM
Would like to get 3D .POB files from Punch! program into Revit.
Tue, Aug 4, 2009 at 2:10:23 PM
Need to convert RVT file to RFA
Sat, May 22, 2021 at 6:14:06 PM
CONVERT RHINO TO REVIT
Thu, Feb 13, 2020 at 5:10:11 AM
CAD to Revit conversion program
Mon, Apr 12, 2010 at 3:49:45 PM
Page generation time: 1.5486
