52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Referencing Sheet Label Parameter
Fri, Jan 20, 2017 at 3:08:18 PM | Referencing Sheet Label Parameter
cboersen
Revit 2016 OS10
My firm wants the referencing sheet in the bottom half of the detail bubble - so I added it.  Now we just noticed that if you reference a dependant view the referencing sheet parameter only reports the sheet that the first dependant view is on even if the view is from a dependant view later in the set.  Has anyone else noticed this behavior and is there a fix?
Next.  My firm would like a running list of the sheets that are referenced.  I noticed that there are first, second, third referenced detail label parameters, but I do not see the same for referenced sheet.  Is there a way to add them or am I missing something in the list?
Thanks for the help.
Sat, Jan 21, 2017 at 6:57:03 AM | Referencing Sheet Label Parameter
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Does this answer your question?
https://rvit.wordpress.com/2009/03/16/referencing-sheet-and-view-issues/
Mon, Jan 23, 2017 at 7:24:53 AM | Referencing Sheet Label Parameter
cboersen
It does answer my question, but not in a good way.  Thanks for the information.
Label in Callout Floor Plan Tag
Tue, Dec 29, 2009 at 3:13:13 PM
adding a parameter to "view-title"?
Thu, Aug 2, 2007 at 4:11:24 PM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
Blank line in text label
Fri, Sep 16, 2011 at 4:07:46 PM
New Title Page Label Using Project Information
Sat, Feb 10, 2018 at 11:54:48 AM
Page generation time: 2.6238
