24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Roof Assembly Level Justification
Wed, Jan 18, 2017 at 1:00:59 PM | Roof Assembly Level Justification
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I think I'm blanking on the method here and I'm hoping someone can set me straight. Is there a way to have the end thickness of a roof assembly be justified to level rather than from the level? See sketch. This probably is a different philosophy from how the tool is designed since I haven't been able to find a setting so far to change it, but if anyone has tried doing this please let me know! Thanks in advance!
Wed, Jan 18, 2017 at 1:22:05 PM | Roof Assembly Level Justification
3.5 Stars: 395 Votes
I don't see any way to change it.... afterall, you build from the bottom up.
Wed, Jan 18, 2017 at 4:31:39 PM | Roof Assembly Level Justification
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
That's what I thought. It makes sense since that is the way you would construct. Just wanted to double check to make sure I wasn't missing something. Thank you sir!
assembly
Mon, Apr 22, 2013 at 5:03:46 AM
justification problems creating general notes.
Mon, Sep 21, 2015 at 9:24:19 AM
Autocad text justification
Tue, Apr 8, 2008 at 7:45:04 AM
Modifying vertical structure in edit assembly
Fri, Feb 9, 2018 at 4:27:20 PM
Uniformat assembly codes
Thu, Jan 31, 2013 at 11:21:11 AM
Page generation time: 4.3418
