99 Users Online (98 Members):
Forums >> Revit Building >> Tips & Tricks >> placing a street, vegetation and barrier or railing on topo surface
0 Posts No Rating |
Hello,I have a topography and i want to place:1-a bunch of trees on the surface but i can't select the topo as the working plane do i NEED to do it by levels? 2- a street following the topo surface? 3- railling or barrier delimiting parts of the the terrain on the surface of the topography?Thank youBes Regards
Revit is not a civil program so the tools for this are limited. There have been many threads similar to your question that you can search for. Always look at the similar threads below your post or use the search function. In your case, I looked for fence since that is similar to what you want. Check out the last post in this thread and look at similar threads.
You can find trees that are properly hosted.
draping street edge onto toposurface |
Mon, Mar 16, 2009 at 4:48:03 PM
topo surface elevation value [ 1 2 ] |
Fri, Dec 15, 2017 at 4:15:36 PM
23
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Site topo street curbs |
Mon, Jul 16, 2007 at 11:58:56 AM
Deleted Topo Surface |
Fri, Apr 2, 2010 at 3:54:58 PM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
