52 Users Online (50 Members):
Forums >> Revit Structure >> Technical Support >> Expansion Anchor Table
28 Posts No Rating |
Instead of a note pointing to an expansion or epoxy anchor listing it's diameter, minimum embedment, edge distance and spacing, the engineers of our company would like to be able to insert a table to a live section where a certain anchor is being show. My first thought was to create shared parameters of the information they want and then create a tag with the parameters inside a square boxed in table. Problem solved. However, one of the engineers commented that sometimes the "spacing" parameter would not be used in the tag. He asked is there a way if the spacing paramter isn't used the table would automatically remove that parameter so it's not showing and the table would become smaller? Is there another way to make this table that has this function? I'm using Revit 2016.
Creating an expansion joint family |
Sat, May 2, 2009 at 10:57:03 AM
How do I set an equality anchor? |
Thu, Oct 26, 2006 at 7:30:59 PM
How to make anchor bolts group?? |
Sun, Jan 31, 2016 at 9:22:24 PM
foldable table??? |
Mon, Nov 29, 2010 at 7:25:54 AM
an automated retractable screen table |
Mon, Jun 18, 2018 at 10:44:36 AM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
