47 Users Online (46 Members):
Forums >> Revit Structure >> Technical Support >> Export Revit to AutoCad
Hi,
I've tried to export a Revit site plan into AutoCad. It did work until a month ago. Now it comes up with this message... see attachement. It does not export into dwg even if I select dwg.
Any thoughts?
Thanks.
S
For the moment, I have exported the CAD into Revit to set up site plan etc. But the original issue is still there regarding exporting Revit to CAD.
Read the error - look up dgn and look at what you have in your file.
Sorry but I don't understand what I need to look up, can you explain, pls? In my opinion if I choose 'dwg' format to create a file to, it should be dwg and not another file format.
I don't believe the problem is the export, it is what is in your file. Did you create this Revit file? What imports do you have in it?
export to autocad |
Wed, Jul 6, 2005 at 7:41:50 PM
MEP AutoCAD Export issues |
Sun, Mar 13, 2016 at 12:46:02 PM
Revit 2011 export to AutoCad |
Thu, Dec 2, 2010 at 9:46:03 AM
Autocad Export - Page Setup Manager |
Fri, Mar 27, 2009 at 9:03:29 AM
Revit Export to AutoCAD DXF/DWG problems with linked files |
Wed, Aug 27, 2008 at 9:42:43 AM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
