41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> door family muntins not visible on one side?
Wed, Jan 11, 2017 at 4:25:11 PM | door family muntins not visible on one side?
KennedyDrafting
REVIT LT  2017
I have a door family that is only displaying some of the Muntins/window grills on one side.  Any ideas why?
Attached is the door family, a project with the door inserted and a pdf for illustration.
Thanks,
JK
Thu, Jan 12, 2017 at 7:10:09 AM | door family muntins not visible on one side?
This is a fmily issue.
Are the muttins full depth through the glass or are there seperate muttins on each side?
Cut a section through the door in the family and look where these muttins are.  They may be in the wrong plane.
Pick the muttins in the family individually and look at their display options.   They may be turned off.
Thu, Jan 12, 2017 at 9:07:25 AM | solved - door family muntins not visible on one side?
KennedyDrafting
The Muntins were locked to the wrong reference plane.  So when the door family was inserted into a project wall of a different thickness the muntins moved to the outside of the glass.
Door Family
Tue, Aug 19, 2008 at 8:56:15 AM
Door family showing one thing in Family Editor another when placed into project.
Mon, Aug 24, 2009 at 3:24:34 PM
Residential Window Muntins
Fri, Apr 5, 2024 at 7:57:35 PM
door with side windows
Fri, Jan 13, 2006 at 11:53:52 AM
Door Family Cut Plan
Tue, Jan 22, 2008 at 10:05:51 AM
Page generation time: 0.9759
