44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> costume curtain wall
0 Posts No Rating |
hi
I want to model dry construction facade with a stone panel with costume structure that the vertical mullion is complete behind horizontal mullion and panel stick oh horizontal mulllion. section below.. can I do this with curtain wall if yes how to change the position of the mullion all over my project. if no how should I model it in family. be thankful if anyone helps me.
Ehsan Anvary
Edited on: Sun, Jan 8, 2017 at 1:04:44 AM
![Beaucoupnice Avatar](user_avatar/46219.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
I would make this as a standard "basic wall" buildup.
For the vertical members, I would just give it the correct depth and assign a plain white solid colour to it and call the material "frame"For the horizontal members, I would just give it the correct depth again and assign the same plain white solid colour to it used in the vertical members "frame".For large scale plan views and sections (1:100/1:200) the vertical and horizontal members layers of the wall will just read as a white solid colour.
When your plan or section or detail scale gets to a size where you are going to need to show the actual horizontal or vertical members, you just add these in as 2D elements or a repeating 2D detail component. (1:20/1:10).
The reason I would do it this way is to not over-detail the information at larger scales.
0 Posts No Rating |
thanks for your answer. i done it with sweep wall profile.
Curtain Wall Panel to Curtain Wall Door |
Mon, Jun 23, 2014 at 9:32:11 AM
Curtain wall not cutting through moulding |
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is |
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall |
Sat, Jan 10, 2009 at 10:01:35 AM
Members: | 2022285 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
