40 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> Room area
Hi, Please see the attached pic (in Revit 2016).
The room area is cut short by something (not by walls, as you can see the grey is the downstairs walls so they are not even close) and not by room separator. Can you tell me what is causing the problem and how to get rid of it.
Thanks,
Suzanne
Please do not bother to reply, it was a wall after all. I will try to sort it out myself, thank you.
If you can tell me how to delete this thread I will do that.
Suzanne
This forum is for learning. Rather than deleting, it is better that you come back with your answer so others can learn.
Room tags with area - area not showing up! |
Thu, Aug 16, 2007 at 6:54:26 PM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
room area calculation |
Thu, Jan 15, 2009 at 5:51:20 AM
ROOM AREA VARIES DEPENDING ON THE DISTANCE FROM PROJECT ORIGIN |
Thu, Jul 12, 2012 at 8:24:17 AM
room area calculations |
Tue, Nov 4, 2008 at 3:48:50 PM
Members: | 2019229 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
