56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> question about work plane and site plan
Mon, Jan 2, 2017 at 6:48:57 PM | question about work plane and site plan
Warchitect
4 Stars: 5 Votes
Im working on a file that has a site plan view (obviously) and in its properties, just below view range, is "associated Level", and its greyed out, with the association being to a level I use I named "Top of Wall" (which is just a level about 8' above the first floor I use) Anyway, How does this get changed? Sometimes I want to place an element using my site plan, but it tries to place it 8 feet above the ground, which makes it hard to work in that view. Is this option not changeable? I must have duplicated a TOW view and renamed it and stuff, but is a "site plan view" supposed to be associated like that? really doesn't hurt, just annoying and I want to fix it.
Tue, Jan 3, 2017 at 6:25:19 AM | question about work plane and site plan
Every plan view is initially set up associated with a level.   All 3d elements will initially use that level unless you change the work plane.  I caution you to be careful in what you do here because you may lose track of this setting and have other problems.  Perhaps you should re-create your 'site plan' using a more appropriate level.
Tue, Jan 3, 2017 at 11:06:44 AM | question about work plane and site plan
Warchitect
4 Stars: 5 Votes
Thanks. I agree, thats what I should do.
get rid of current work plane and 3D snapping
Fri, Nov 10, 2006 at 3:26:53 AM
ABOUT SET UP WORK PLANE
Thu, Aug 5, 2010 at 9:30:57 AM
Work Plane issue....
Fri, Apr 18, 2008 at 11:50:58 AM
site plan disappears intermittently
Thu, Mar 16, 2017 at 9:21:13 PM
Orient a view perpendicular to a work plane
Thu, Dec 17, 2009 at 11:52:40 PM
Page generation time: 1.4264
