40 Users Online (39 Members):
Forums >> General Discussion >> Revit Project Management >> saving 3d view camera angle
Ran into a puzzling problem today. I have a 3d view placed on a sheet. I modified the camera angle of that view slightly. Then I saved, synced, and went to lunch. When I opened the view after lunch, it had gone back to the original posiiton! I repeated this multiple times, with the same result. The only way I found to fix this is to modify the camera angle in the original view, then duplicate the view and place the duplicated view on the sheet and delete the original view. Has anyone run across this? If so do you know why this would be happening?
Fill what is empty. Empty what is full. Scratch what itches. |
Nope, never experienced this unless you undo your steps.
You could lock the camera view to fix it, in position.
saving 3D view? |
Fri, Jan 9, 2009 at 8:59:55 AM
perspective angle |
Thu, Mar 29, 2012 at 7:43:10 AM
Camera Angle Matching |
Mon, Oct 18, 2010 at 6:52:26 AM
Materials in a camera view |
Mon, Mar 25, 2013 at 8:17:41 AM
Editing Walkthrough Cameras field of view (FOV) in Plan View |
Fri, Jun 26, 2009 at 1:17:38 PM
Members: | 2037258 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
