37 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> family editor views
16 Posts No Rating |
i'm not proud, but i did a rather stupid thing - i created a custom shelving unit in the family editor, and i unfortunately drew out the entire front elevation while i was in the "floor plan" view. so, when i finished and imported the shelves into my project, they end up flat out on the floor instead of rising up along the wall. is there a way that i can somehow edit the family to fix this?!
thanks.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
yes, go to your family, go to side view and rotate, if you have any constraints in the family, you will need to redefine them...
Sheets in family editor |
Tue, Jan 10, 2012 at 6:14:35 PM
exploded views and sheet feature in revit family editor |
Mon, Mar 24, 2014 at 10:55:30 AM
Draw Order in Family Editor |
Wed, Aug 28, 2013 at 3:07:31 PM
Family Editor: works... then doesn't! |
Fri, Sep 2, 2005 at 5:23:05 PM
No Annotate tab in Family Editor; no detail lines |
Tue, Sep 8, 2009 at 3:42:49 PM
Members: | 2022349 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
