36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Site Plan
Wed, Dec 21, 2016 at 2:03:43 PM | Site Plan
plyrockie59
Hello, I am using revit 2017. I am having a problem with the site, I imported the cad drawing and then tried to make a topo surface from that. The problem was that the topo surface was about 600 feet above my model. I tried several different things to keep the elevations on the topo surface the same but couldnt bring the model building to it without changing the elevations of the topo. I made a seperate model with the site plan and inserted the building into it and it worked perfectly. But now my problem is bringing it into the old model for the site sheet. When I bring it in, the building isn't being shown and the existing building in the model is still 600' off. How would I go about bring it in? Or will I have to just print sheets from a separate model for the site plan. Thank You in advance.
Wed, Dec 21, 2016 at 2:19:06 PM | Site Plan
The site is not too high, your building is too low.  (Assuming all of the site data is correct.)
You need to relocate your project and you can read about this in your help.   If you don't have a lot of crazy levels, you can always go to an elevation, dimension lock all of your levels then grab your loweset level and move it up to where it belongs.
Wed, Dec 21, 2016 at 6:05:04 PM | Site Plan
AmyEAmyW
Change the elevation of your project base point from 0'-0" to what the elevation of your F.F. level is in relation to the grade (ex. 600'-0"). Then, select the topography in elevation and move it down the amount you changed the project base point to.
site plan disappears intermittently
Thu, Mar 16, 2017 at 9:21:12 PM
Problem with Reigion Hatching on Site Plan [ 1 2 ]
Tue, Feb 25, 2014 at 4:19:15 PM
26
help!!! deleted site plan!
Fri, Aug 7, 2015 at 9:23:10 PM
13
Advice on creating a site plan
Mon, Jul 12, 2010 at 5:04:03 PM
invisible road carparks and landscape on site plan
Fri, Aug 28, 2009 at 6:44:33 AM
Page generation time: 12.1756
