38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> utilizing Master Project File w/ linked building models (sharing details) (2017)
Wed, Dec 21, 2016 at 1:03:43 PM | utilizing Master Project File w/ linked building models (sharing details) (2017)
ledgewood33
I have a co-worker who is working on a project that consists of several buildings on a site. I recommend that he have separate files for each building and a separate file for the site/ topography (Master). that he link the building files into the Master (site/topography )file. he was hoping to have one set of details that can be used for all the buildings. 1. is this an efficient way of handling this (each bldg. separate & separate site)? 2. how would you recommend utilizing details between buildings?
Wed, Dec 21, 2016 at 1:52:05 PM | utilizing Master Project File w/ linked building models (sharing details) (2017)
I have not seen a good solution for this other than putting all of the details in a project with a reserved set of view numbers/sheet numbers then using fake sheets in your main project that match this seperate file and referring your callouts accordingly.
I don't like that process so I always import those details into my host file.  That's really not much of an issue if you are not changing these details.
Section / Elevation annotation in Linked Revit Models
Fri, Jul 20, 2007 at 4:28:20 PM
looking for a keynote master file workaround
Fri, Apr 3, 2009 at 6:57:06 PM
best practices for sharing linked models
Fri, Nov 5, 2010 at 10:15:59 AM
One File or Linked Files
Wed, Apr 20, 2011 at 6:35:11 AM
File size issues: Linking multiple Buildings into a Master Site File
Tue, Mar 8, 2011 at 9:52:00 PM
Page generation time: 2.7301
