45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Have to show recessed basket lighting in a render - I can't find a good one
Fri, Dec 16, 2016 at 4:07:02 PM | Have to show recessed basket lighting in a render - I can't find a good one
NeoBahamut
They don't seem to have a common name for these popular buggers but basket seems to be the most common.
How would you render it to show the light correctly?  Nothing I have tried works. Most available ones don't even drop in an ACT ceiling.  They are face based.  Talk about time consuming to put these in.
I wish the manufacturers would make correct lighting for these.
Here is an example
http://www.junolightinggroup.com/Images/JunoLighting/461X461%5CIN_S2X2BO_WB.jpg
Fri, Dec 16, 2016 at 4:09:50 PM | Have to show recessed basket lighting in a render - I can't find a good one
NeoBahamut
I am using Revit 2017
Fri, Dec 16, 2016 at 4:25:09 PM | Have to show recessed basket lighting in a render - I can't find a good one
Did you look on autodesk seek?
Fri, Dec 16, 2016 at 9:46:10 PM | Have to show recessed basket lighting in a render - I can't find a good one
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Have you tried OOTB Recessed Direct-Indirect Light - Symmetrical.rfa?
Mon, Dec 19, 2016 at 7:39:55 AM | pijpiwo
NeoBahamut
Quoting pijpiwo from 2016-12-16 21:46:10
When you turn the light on for rendering, it totally washes the geometry away. It is just a flat plane of light. Maybe if I photoshop (waste of time) it in.....  It shows up (off) when the lightsource is turned off
My boss is obsessed with making things look like the real deal even though it is in a bathroom.
These lighting companies should have figured out a plug and play nice nice method to sell their products.
Can't figure out how to insert Recessed Can lighting into ceiling plan
Mon, Aug 16, 2010 at 12:50:05 PM
Recessed Lighing IN wall
Tue, Mar 12, 2013 at 7:10:13 AM
Recessed Lighting
Tue, Sep 28, 2004 at 1:13:14 PM
How to show lighting fixtures on floor plan
Mon, Nov 6, 2006 at 10:15:38 PM
Rendering & Lighting
Wed, May 12, 2010 at 1:46:13 PM
Page generation time: 1.8213
