64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Arch wall in Strucural Template not visable in 3D view
72 Posts No Rating |
This should be really easy. I have started a model w the default Structural Template in Revit 2017 Premium Building Suite. I understand that by doing so things that are not structural are not displayed by default. I just need to turn on an architectural wall in my default 3D working views. I am having trouble figuring out where to turn it on. it should be simple, but in VG all walls are turned on. What setting am I missing. Thanks !
----------------------------------- Imagination reveals truths reality obscures. |
ok it was simply making the wall structural in a check box in the properties of the wall element. doh !
You probably could have changed the view to coordination and accomplished what you want.
this is what i was missing and it was like on the tip of my tounge or brain in this case.... so where is that??? the bottom right? still looking for this "coordination" setting!
Edited on: Thu, Dec 15, 2016 at 9:05:51 AM
It is a view property.
Exterior walls not visable |
Mon, May 11, 2009 at 5:28:23 PM
Visibiliy of components |
Mon, May 24, 2010 at 3:52:21 PM
View properties schedule- Revit Arch 2009 |
Thu, Oct 23, 2008 at 5:06:20 PM
Arch Template Size |
Fri, Apr 6, 2012 at 6:52:41 AM
view template applied to each placed view |
Thu, Jul 2, 2015 at 2:36:37 PM
Members: | 2056202 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
