90 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> recognize solid imported objects as mass elements...
Fri, May 19, 2006 at 10:06:12 AM | recognize solid imported objects as mass elements...
belyo
if autocad and Viz can recognize sketch up masses as mass elements and allow you to manipulate as such, revit should be able to also... it's ludicrous that you can't use an imported sketch massing as a mass family or whatever in revit...
Tue, Jan 20, 2009 at 10:26:33 AM | recognize solid imported objects as mass elements...
ledgehead
You can; Massing, create mass, file, import/link, cad formats, finish mass, done.  Make sure masses are turned on under 'v v' not just show mass.
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
Newbie - Need help with mass elements
Mon, Feb 8, 2010 at 1:11:14 PM
printing mass elements
Wed, Dec 10, 2014 at 2:46:06 AM
How do I remove faceting from imported 3d objects?
Fri, Feb 22, 2013 at 7:26:40 AM
Chaning mass objects
Fri, May 8, 2009 at 3:41:08 AM
Page generation time: 0.9747
