84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Copying from one file to another
Sun, Dec 11, 2016 at 1:23:23 AM | Copying from one file to another
Olzhas
My friend did level 2 while I did level 1. I am trying to combine them so when I copy from his file and place it to mine it does not match. Is there a quick way to copy with the base point? Should I adjust project base and survey points. Please advise if there is a simple way. Your help is much appreciated.
Sun, Dec 11, 2016 at 7:47:57 AM | Copying from one file to another
archigrafix
5 Stars: 4 Votes
Have you tried linking level 2 into level 1? Then you can copy what you need from level 2, or keep it as link. I assume you guys have planed some way of having the models in the same references, either using hte same zero point (local revit point), or by using axis. Good luck.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Worksets: Copying from one drawing to another?
Tue, Jan 5, 2010 at 4:53:39 PM
Copying Placeholders to a new file
Tue, May 6, 2014 at 10:54:34 AM
Copying text & dims from one file to another in 2012
Tue, Nov 25, 2014 at 5:22:34 PM
Copying elements from a linked architectural file...
Thu, Sep 25, 2008 at 9:01:59 AM
Copying Receptacle's
Thu, Jul 13, 2017 at 11:50:36 AM
Page generation time: 0.8897
