65 Users Online (64 Members):
Forums >> Revit Structure >> Technical Support >> Adding Base Level & Top Level to a column tag
I am modelling a complex industrial building with many partial floors supported on posts or hangers.
For example I have a post starting on Level 8C and going upto Level 9D
I would like to be able to add the Base Level and Top Level of the post in the column tag.
Base Level & Top Level fields do not appear in the list of available fields for a column tag.
Is this possible?
Regards
Frank
If I have read your desciption correctly, I have created a very simple Schedule of Structural Columns using the following Feilds:
Type Mark
Type
Base Level
Base Offset
Top Level
Top Offset
Count
I then Placed 5 columns with different start points (base) and different top points with the resulant table.
you can add other standard fields like Length and Mark if needed.
All the Fields are standard fields available for the Category of Structural Columns - I didnt create any custom parameters.
I hope this may be of help
(example taken from Revit 2015 - because i had it open at the time)
1 Posts No Rating |
Old topic but as has been scheduled here can the base & top levels be added to a structural column tag family? as far as I can see there is no paramter for top and base levels but there is for base offset and top offset?
Thanks
Lee
Adding a Numerical Level Parameter to a Room Tag |
Mon, Jul 23, 2018 at 10:53:59 AM
Elevation at Top Parameter for Structural Column Schedule? |
Mon, Nov 9, 2015 at 4:56:15 PM
sort door schedule by level without adding "level" column? |
Tue, Aug 15, 2017 at 11:27:04 AM
Newly created column family not inserting correctly |
Tue, Feb 22, 2011 at 8:03:19 PM
Adding Base/Top Constraint to Family Member |
Wed, Sep 9, 2009 at 5:16:39 PM
Members: | 2030517 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
