Forums >> Revit Building >> Technical Support >> how to stop snapping to floor hetch?
how can I stop revit from picking hetch floor lines?
I use revit 2017
Ben
Learn to use the tab key and the funnel filter.
Thanx for your answer,
I'm femiliar with this methods.
With this methodes i have to change the setting every time.
My question is: is there a way to permanetly stop the snapping to the floor hetch (not the borders, just the hetch)?
Ben
Turn it off in view.
so there is no way to stop snapping to a hetch other than turning every hetch off in the specific view?
You really have not explained what you are doing so our answers are limited.
BTW - I assume by 'Floor hetch', you mean a material HATCH pattern assigned to the floor surface but you really don't say that either.
sorry for my lame english...
that exactly what i ment.
when i'm working in a plan view, for example, and i'm using the align command, i can align to the material hatch pattern assigned to the floor surface.
is there a way to avoid that option completely?
I have given you your options and the best is to use the tab key to select what you want to align to. It is a very simple solution.
Thanx
I am trying to draw over a pool surface with 20mm mosiac tiles covering it and the snapping is a nightmare. Tabbing isnt really a solution either.
Anyone got a more practical solution?
