72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Shade view of toposurface
Fri, May 19, 2006 at 4:56:46 AM | Shade view of toposurface
ChrisMackay
Hi, I have a problem i cant figure out. How come all the regions of my toposurface shade in a grey color despite have the relevant materials assigned to them with various shade colors?? this is probably a pretty stupid question but i would appreciate some help all the same.
Fri, May 19, 2006 at 6:47:57 AM | RE: Shade view of toposurface
coreed
coreed Avatar
4 Stars: 16 Votes
Question By a Revit User
There is a grey plane that is almost like a floor. on the outside fof my house. How do I get it to lower so that I don't see the grey but I do see my grass?
Previous Answer By Tom Dinmn
They grey plane is most likely a "ground plane" Ground planes are useful if you don't have a site plan and just want a meterial to appear in your rendering at a certain level.
To get rid of the ground plane yu have to check in two places:
Settings>Sun and Shadow Settings [un-check 'ground plane']
And:
Rendering TAB>Settings>Environment [un-check 'ground plane']
Why there are two places for ground plane I haven't figured out yet. Hopefully this will clear up your problem.
From coreed;
This is learning process for all of us, there are no stupid questions. only a quest to learn
HTH
Post edited on 2006-05-19 09:43:48
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, May 19, 2006 at 9:35:12 AM | RE: Shade view of toposurface
TomDorner
4.5 Stars: 25 Votes
Also, make sure that if you are using phases that you set your phase filter for the view to 'show all' or 'show complete'. If you have the phase filter set to anything else the material may be picking up the graphic over-ride of the material called 'phase-existing' which is set to gray.
As a side note, someday someone should compile a FAQ for Revit as these questions come up again and again and it is hard to search for them on this and other forums. Maybe in my spare time.!
P.S. the key to decoding my username is: Tom D in MN (Tom [first name], D [last initial] in, MN [minnesota]) Worked better when I lived in Arizona as it was tomdinaz which kind of rhymed. Known as just Tom Dorner out on AUGI.com
Post edited on 2006-05-19 09:38:45
Post edited on 2006-05-19 09:39:16
Tom
www.reviteer.com   http://twitter.com/Reviteer
shade diagrams
Tue, Apr 21, 2009 at 8:04:34 PM
to shade or not to shade
Fri, Jan 25, 2019 at 4:02:18 PM
change shade color in views
Tue, May 15, 2007 at 11:40:21 AM
rotating a horizontal sun shade to a vertical sun shade
Fri, May 12, 2006 at 1:14:09 AM
how to view a toposurface with thickness in a elevation ou in a 3d view??
Thu, Jun 16, 2011 at 1:28:30 PM
Page generation time: 0.7533
