61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Formula - 2 x 'if' conditions in one line?
Wed, Nov 30, 2016 at 7:06:22 PM | Formula - 2 x 'if' conditions in one line?
Justmissbee
Hello,
Please help me wrap my head around this:
I currently have an 'if'  formula that states a standard height condition.
if(Height = 260 mm, Result if True A ,Result if False B)
however I want to ADD another if statement that reads:
if(Item, Result if True C, Result if False B).
Can I put the two in one? so that the component will adjust accordingly to Height, AND/OR Item(yes/no)
Thu, Dec 1, 2016 at 7:18:33 AM | Formula - 2 x 'if' conditions in one line?
marmiketin1
4.5 Stars: 10 Votes
You can do something like this
 if(or(Height = 260mm, Item = ???), A, B)
The first thing in an if statement is a conditional and you can use or, and, not statements for this conditional.
See your help
Edited on: Thu, Dec 1, 2016 at 7:23:00 AM
Numerate 'Sheet Number' parameter for match line family
Mon, Apr 28, 2014 at 10:17:51 AM
Creating a 'Jogged' Section Line
Tue, Dec 11, 2007 at 8:26:06 AM
Changing paramaters of 'Title with line'
Wed, Sep 20, 2006 at 9:47:18 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Adding line styles to Revit's Default styles
Mon, Apr 26, 2010 at 11:29:50 AM
Page generation time: 1.0425
