127 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Method to Align Section view to modeled elements
Wed, Nov 30, 2016 at 11:14:57 AM | Method to Align Section view to modeled elements
leothelionator
I have a portion of building that is set to an odd angle and I made a quick section cut without realizing that it was not aligned properly to the view.  Now when I open the section view, I can zoom in and see that everything is off kilter by a hair.  Is there a way to re-align the section view with the modeled elements?
I tried rotating, but there is no snappable part of the section to guarantee that the correction is any better.  I am using version 2016.
Wed, Nov 30, 2016 at 1:06:52 PM | Method to Align Section view to modeled elements
Why not just cut a new section that is perpindicular?
I have rotated sections in the past but the process is not easy since the rotation center is not on the section cut.   You have to move that point.  The other problem is Revit doesn't like small increments.
HELPPPPPP
Thu, Apr 23, 2020 at 9:57:31 AM
DIFFERENT LINE THICKNESSES FOR STRUCTURAL FRAMING ELEMENTS IN SECTION
Tue, Sep 28, 2010 at 7:16:15 AM
rotating elements in section view
Thu, May 1, 2008 at 11:24:28 PM
Topo Thickness Issue in 3D view
Thu, Jun 13, 2024 at 7:05:49 AM
None of the created elements are visible in Section View
Wed, Mar 25, 2009 at 1:48:54 PM
Page generation time: 1.0649
