35 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit Scaling with 27" UHD Monitor
Fri, Nov 25, 2016 at 12:42:48 PM | Revit Scaling with 27" UHD Monitor
chinomoreno
Hey Guys,
I just upgraded from two dual 24" dell monitors (1080p) to a dual 27" setup (1440p) at the office and have come up with a scaling issue solely within Revit where it cuts off text within the ribbon. I know this is an issue for 2k and higher res monitors, but why is this affecting mine? I have done all the usual tinkering with new drivers for the video card and for the monitors. Also, as you may expect, I have my windows scaling set at 125%. Clearly the issue is with that as when I turn that off everything is fine, and extremely small... Anyone deal with the same issue? I have looked everywhere and I can't come up with any fix. Also, why doesn't revit let you remove certain icons or tabs from the ribbon? This seems so basic, just add a menu option to adjust what you want to see in there...
Thanks in advance, see photo.
Dell 30" LCD Monitor
Wed, Sep 6, 2006 at 9:39:56 AM
13
copy/monitor Levels
Fri, Sep 18, 2009 at 10:24:15 AM
24" v 26" monitor
Thu, Jun 19, 2008 at 8:27:50 PM
model: column-"properties" dims not scaling to whats shown on drawing
Fri, Dec 12, 2008 at 3:10:11 PM
Worksharing Monitor
Fri, Jun 6, 2008 at 1:27:29 PM
Page generation time: 3.4671
