58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing Elevation of Linked Revit Models
Wed, Nov 23, 2016 at 3:33:45 PM | Changing Elevation of Linked Revit Models
Warchitect
4 Stars: 5 Votes
So I linked in a detached garage model to my main house model. But I can't figure out how to adjust the elevation of the model, as you can see in the pic, its floating above the first floor area a lot.
Any advice?
Thu, Nov 24, 2016 at 8:23:47 AM | Changing Elevation of Linked Revit Models
Links work similar to groups.   You can just selec t it and move it.
Thu, Nov 24, 2016 at 11:41:00 AM | Changing Elevation of Linked Revit Models
marmiketin1
4.5 Stars: 10 Votes
Go to a section or elevation, select the link and then move it up to where you want it. You can then save position/publish the new coordinates back to the link so it knows where its new position is.
Sun, Dec 4, 2016 at 11:31:46 AM | Changing Elevation of Linked Revit Models
Warchitect
4 Stars: 5 Votes
HI. nether option worked. the linked model will not move in section or elevation. it only moves left or right.
Edited on: Sun, Dec 4, 2016 at 11:32:34 AM
Mon, Dec 5, 2016 at 9:27:54 AM | Changing Elevation of Linked Revit Models
Then someone placed a dimension lock to a level.
Does this linked model have levels?   If so then maybe the first floor level is locked to the host floor level.  If that was done with a dimension that is now missing, you should be able to move it detached. I sometimes remove dimension locks by adding the dimension, locking it then unlock it.
Section / Elevation annotation in Linked Revit Models
Fri, Jul 20, 2007 at 4:28:20 PM
View Filters and Linked Models
Tue, Mar 28, 2017 at 7:53:31 PM
Elevation visibility in linked models
Fri, Feb 25, 2011 at 9:54:38 AM
Linked Models - Element / Component Identification
Tue, Dec 7, 2010 at 4:10:55 PM
Temporarily display only analytical model for linked revit models
Mon, Oct 17, 2011 at 3:21:59 AM
Page generation time: 3.3495
